What to buy?
Miseryguts
Current Ride: Burgman AN400 K8
Re: What to buy?
Post by Miseryguts »
poldark wrote:Good choice and safest bet.
What age/type is it, check the V5 for the model reference, will be either K5, K6, K7 etc after the AN400 part.
You may benefit from a Givi screen if not already fitted, Dr Pulley sliders would be an easy upgrade to the OEM rollers when/if they need replacing. Don't be tempted by any performance belts, stick to OEM though you can buy from EBay (Italy) too.
Linky
If you need tyres anytime soon the Michelin CityGrip are excellent and well recommended, good option is buy direct from oponeo.co.uk and take loose wheels to a local place to fit.
It's a 2008 K8
Cheers
Re: What to buy?
Miseryguts wrote:[
Blinking heck!!
Already bricking it, as never even been a pillion on a scoot, seems Wierd sitting position not having a tank between your legs.
Plus it's been about 5 years since my last bike a Kawasaki ZR7S
In about 5 minutes, you'll be wondering why all bikes aren't designed like the Burger! Or maybe you'll notice that you've ridden for miles and you haven't got any back/wrist/arm pain!
Miseryguts
Re: What to buy?
Got it !!!!
Got my AN400K8 Burgman today and WOW!!
All my concerns about grabbing a handful of rear brake thinking it was the clutch didn't materialise.
Absolutely fantastic, it's so well balanced with a low c of g and not having to think about changing gear is so relaxing, as is the seating position.
Just wish I'd tried a maxi earlier, now the cleaning and polishing starts as the last owner wasn't to bothered about removing the dead flies off the bodywork most have been on since the summer at least.
Any body got any advice on what to use to remove them from the screen without scratching.
x10350
Current Ride: x10 350
Re: What to buy?
Post by x10350 »
I had one and enjoyed it
Hope its undersealed as mine fell apart lol!
Enjoy
burgerman
Current Ride: Honda FJS600 Silverwing
Re: What to buy?
Post by burgerman »
Miseryguts wrote:Got it !!!!
Lay a wet cloth over the screen, and leave for 10-15 minutes, then take it off and wash the screen with a sponge and soapy water. Dry it off with a soft cloth.
I also use Maguirs PlastRX to polish my screen - just don't get too enthusiastic with the polishing!
Globs
Current Ride: Piaggio X10 350
Re: What to buy?
Post by Globs »
I'd go for a Majesty TBH.
SInce the 2007 model Burgman 400s have had clutch judder issues (Google it), I have no idea about the Majesty's faults (Although check valve clearance servicing IIRC) but it just seems a good alternative ;)
I'm not saying post 2007 models will suffer, just that a few do.
Re: What to buy?
Some Majesty 400s will be scrapped before they need the valves looking at, checks are at 24,000 mile intervals.
Miseryguts
Re: What to buy?
Globs wrote:I'd go for a Majesty TBH.
Too late I've just got a Burgman, well pleased with it.
But thanks for the advice.
