all of my riding is a 2 b i get around 48 mpg gilera states 50mpg average, so a bit less but if you use highways more this would increase your mpg, i also use a
Sprint Super Competition Air Filter is a SPECIAL DRY POLYESTER type. This is made from an accurately manufactured fine micron mesh which filters more of the dirt whilst also flowing more air. It can be cleaned more easily and re installed immediately thus saving the cost of the specialist cleaner and oil and works out cheaper over a longer period, plus the added benefit of improved air flow means increased power. the scoot can gulp as much air as required and its a direct replacement £35 delivered from
http://www.motorcycle-exhausts.co.uk/Sp ... -5883.html" onclick="window.open(this.href);return false; good price as you will find them every were else for £60
my thinking is, regular oil and filters and good spark plug, i use a brisk spark plug LGS
http://www.briskracing.com/premium-raci ... lug-detail" onclick="window.open(this.href);return false; bought mine from america but can get them in UK i have found it to be flawless, so fuel burn sorted, had the plug out after 1000 miles and no carbon residue present so burning all fuel
and also air filter for smooth running, then how to get the power to back wheel, dr pulleys, and on the clutch side the Polini Evolution Maxi Clutch Bell, no heat build up which stops slip.
http://www.adrenalin-pedstop.co.uk/p/Po ... -3366.aspx" onclick="window.open(this.href);return false;
i have the rear suspension arm (blue) turned up 5 notches out of the 11 steps so the scoot is set up for maneuvering yet for rare carriageway use, i feel its more responsive in the turn
then look after your brakes, bleeding and refreshing is easily done with a one way valve pipe, i made mine but dont spend a fortune on one, some thing like this
http://www.ebay.co.uk/itm/VIZIBLEED-ONE ... 4845b45eb5" onclick="window.open(this.href);return false;
this is all i think you need, i suppose if i had the money i would get a different exhaust, but its not a need more of a desire.
