Sunday 29th
richie the 1st
Re: Sunday 29th
Seeing as i passes my car/bike test way back in 1977 will be on my Honda sh125.So see some of you at Blackheath tea hut then on too High Beech tea hut too..
Old honda sh125.
New Honda sh125.
Ride free,ride safe.
New Honda sh125.
- halfabusa
Re: Sunday 29th
just noticed the bike is currently on 24722 miles, and according to the notes in the service details, the belt change comes up at 24800ish. Which means after this week's commute, i may have a belt change light on. Would it be safe to ride a little while longer till monday?? I'm undecided...
woozy-uk
- Current Ride: PCX 125
Re: Sunday 29th
get a new one and put it on yourself before the sunday ride if possible?
- halfabusa
Re: Sunday 29th
nah mate i'm not that good. My diy skills are only level up to oil+filter+air filter + spark plug changes and nothing else.
woozy-uk
Re: Sunday 29th
hope you manage to make the sunday though
also did i see you today on the way to aye gee? looked like the Tmax at about 4pm
- Current Ride: Forza 125
Re: Sunday 29th
I've seen a Tmax belt at 12000 miles, it was unworn,so the dealer reused it on another bike. The belt last a long, long time. The most important thing is to keep the belt cover filter clean, as this helps it to run cool. It will be fine.
- halfabusa
Re: Sunday 29th
woozy - no, i didn't use the bike at all today. Must have been someone else.
Dave - i'll get the filters changed together with the belt, but i believe you're talking about a mid-term maintenance of taking them out and cleaning up, rather than getting them changed on each belt change, which is not something i've done. Do you recommend a periodic cleaning of filters in between belt changes, or is simply changing the filters together a good enough preventive maintenance?
Deleted User 62
Re: Sunday 29th
Belt filters are cheap enough...they are available on Flea Bay for £17 for the pair.
- halfabusa
Re: Sunday 29th
i guess that means you do recommend filter changes in between belt changes then
I'll keep that in mind for the next period
Re: Sunday 29th
Do the belt after, I went on a ride last year having changed rollers which means taking the belt off, and shredded the belt on the M25 at 'normal for most people' speed and never made it to the ride out.
