New Xmax 300
Ralph
Re: New Xmax 300
Post by Ralph »
You take the screws out then you have to pull the panel out sideways at the top once it as come away you then slide it down,
half the problem is knowing which bit is going to move, it does not take a lot of force once you get the hang of it.
Ralph
Nr Fleetwood
Ralph
Re: New Xmax 300
Post by Ralph »
Only thing I don’t like about mine is no oil warning light, I do have a gauge that I may see if I can fit but to buisy riding the thing to bother up to now.
Ralph
Nr Fleetwood
Greyerbeard
Re: New Xmax 300
Post by Greyerbeard »
Ralph wrote: Wed Dec 05, 2018 8:50 am You take the screws out then you have to pull the panel out sideways at the top once it as come away you then slide it down,
Screws have been out, and every clip on the side released, but something is holding it in the middle, out of sight. I've pulled it, slid it, and sworn at it, and pulled it again to the point of snapping. It Will Not Come Off...
1964 Matchless G3
1989 Honda C90
1998 Honda CB250 Nighthawk
2025 Honda ADV 350
muddyfox
Re: New Xmax 300
Post by muddyfox »
Greyerbeard wrote: Thu Dec 06, 2018 8:34 am
Sounds like you have not found the small poppet rivet at the bottom . You need press the middle of the rivet to release it and then just press the middle back in to re use use it on re assembly.
Sorry if it sounds like I'm teaching you to suck eggs.
Muddyfox (Nottingham)
Ride safe
Greyerbeard
Re: New Xmax 300
muddyfox wrote: Thu Dec 06, 2018 10:21 am
There isn't one on the 300!
I had no trouble with the similar panel on the T-Max, and I'm pretty handy with vehicle servicing...but this has me beat!
When I get chance, I'll go to dealer and let them snap it...
1964 Matchless G3
1989 Honda C90
2025 Honda ADV 350
phantom309
Current Ride: nc750sa
Re: New Xmax 300
Post by phantom309 »
not sure about panel removals but did find this
https://youtu.be/9q95yBd9IMk
Normsthename
Re: New Xmax 300
Post by Normsthename »
It’s dead easy to remove, Ive had some panels that were a nightmare to remove.
Just remove the two self tapping screws and then pull the trim edges outwards.
As soon as you get the edges out it virtually falls off :)
1975 Honda GL1000 Goldwing
Greyerbeard
Re: New Xmax 300
Normsthename wrote: Fri Dec 07, 2018 8:59 pm
I promise you - mine doesn't!
1964 Matchless G3
1989 Honda C90
2025 Honda ADV 350
Ralph
Re: New Xmax 300
Post by Ralph »
Turned into a side road today only doing maybe 20 mph and the Xmax slid sideways by a good foot or two,
reactions included a Dave Bickers style boot to the ground, the scoot sorted it's self out was surprised how
smooth the slide was and that I did not go down, quite impressed,
Went back to look and there was a patch of stuff like black gritty sand it was so slippy the scoot did not want
to set off, be careful out there.
Ralph
Nr Fleetwood
Re: New Xmax 300
Ralph wrote: Mon Feb 18, 2019 5:32 pm
Oddly I had an encounter with something similar today...just whizzed round a corner over a little hump (sun in my eyes!) and then found there was loads of some black material just where I wanted to turn in for the next corner! Fortunately it was grippier stuff than what you came across!
