New Vespa (more BHP) GTS 300 For 2019
Re: New Vespa (more BHP) GTS 300 For 2019
Julian, do you want me to do yours? You can ride mine first after I've converted it to help you make your mind up! You won't be disappointed, they go like bloody hell! Totally different to the standard bike. You get a real punch in the back when you twist that grip. It's like a two stroke coming on to pipe with a sudden surge of power. :o
Mines the gt 200 carb I have looked at the full kit with V4 head and cam ect .Ill be selling mine next year so not worth spending on it plus it's got 30 k plus kms on it .Germans do a Kublar kit think it's called with longer stroke cam for 125 200 a bit of crankcase machining needed that along with mallossi kit takes power way up to 300 levels .Be about same price paid for burger 400 just for parts .
Thanks for the offer tho .
https://www.sip-scootershop.com/en/prod ... r_kbr10002
That's one uses piaggio cylinder I think they do one with Mallossi kit as well .
bn1966
Current Ride: Vespa GTV 300 SG
Post by bn1966 »
About to upgrade my GTV SG 300, going very mild with a Polini 'Hi Speed' Variator, kevlar belt, Polini 'Racing' clutch & clutch bell. Hopefully a bit more responsive & no flat spots.
The Polini gets good results. Let us know how you get on.
Has been maxi tours wrote: Thu Dec 06, 2018 10:41 am Mines the gt 200 carb I have looked at the full kit with V4 head and cam ect .Ill be selling mine next year so not worth spending on it plus it's got 30 k plus kms on it .Germans do a Kublar kit think it's called with longer stroke cam for 125 200 a bit of crankcase machining needed that along with mallossi kit takes power way up to 300 levels .Be about same price paid for burger 400 just for parts .
Will you be getting maybe a 250/300 to replace it with?
At the moment no I've brought a 400 Burgman .I do like the big Vespa events tho so still have an interest in them .
gasgas
Current Ride: Sym 300i
Post by gasgas »
"The single camshaft distribution system with roller tappets gains a camshaft with optimised timing and valve lift speeds"
So why didn't they bother optimising the timing and valve lift speeds on previous models then? Presumably they were rubbish.
Too busy quaffing vino on their 2 hour lunch breaks, I guess. :)
So, as it is now optimised, it is by definition impossible to do it better, so there will never be any more 'optimised' or 'improved' versions. You cannot improve on what is optimised - - - or is it just 'optimistic'?
Now Now, some marketing type took several days to come up with that line!!
Piaggio vino Quaffers have been making scooters since 1946 so must be doing something right .
