Advice for spark plugs
Liam
Re: Advice for spark plugs
Post by Liam »
chippie wrote:
Do you know the number of the plugs for the mk3 t-max and where you got them from
don't know if mine are caped or not and don't want to take plastic off to find out,thanks.
Hi Frank.
I've got AOR14LGS in my mk2
I was a bit concerned as the brisk is longer than a standard plug but the engine hasn't gone bang.
Double check here. http://www.lpg-kits.com/" onclick="window.open(this.href);return false;
No mention of tmax but go to the left hand side, motorcycle plugs, then to cross reference.
The standard tmax plug for all engines (as far as I know) is NGK Cr7e which equates to AOR14LGS
You need the ones with the caps off. So either get them from the american site or get them from here
http://www.ebay.co.uk/itm/360394108178? ... EBIDX%3AIT" onclick="window.open(this.href);return false;
and drill the 3 tiny spot welds off like I did. The cap willthen unscrew.
But if yours goes bang, don't blame me! :kiss:
If ordering from the American site then it's 'nc' on the end for 'no cap'. I don't think you need the caps for your spark plug lead fitment.
chippie.. american plug here with screw less cap you will need two http://www.ebay.co.uk/itm/HIGH-POWER-PE ... 257b05afb2" onclick="window.open(this.href);return false; takes two weeks to arrive :D
pointburgman
Current Ride: BMW R1100RS Trike
Post by pointburgman »
Diffidently worth doing, i spent all day yesterday running around on the new plugs and really found a great improvement in the smoothness of the bike. Thx guys
Proud To Be a Member Of The Ugly Bunch
I Don't Discriminate, I Hate Everyone
chippie
Current Ride: T-MAX MK3
Post by chippie »
Thanks for the info lads ordered them today from http://www.lpg-kits.com/" onclick="window.open(this.href);return false;
They are AOR 14LGS[nc] for the MK3 £25 including postage.
chippie wrote:Thanks for the info lads ordered them today from http://www.lpg-kits.com/" onclick="window.open(this.href);return false;
be careful and inspect when you get them, as they may have welded screw caps on them from this supplier :D think you need them off.. some muppets tried and failed, or change your plug suppressors for taking the screw tops :?:
chippie
Post by chippie »
The [nc]denotes no cap.
just a warning to look at your plugs when arrive as this is the seller on ebay where muppets have noted soldered plug tops when arrived :kiss:
chippie
Post by chippie »
Now thats what I call service ordered them on Saturday arrived today.
