MrGrumpy wrote:....You don't need it to be high to be effective actually......
I don't know if its any use to anybody and I've never studied that particular setup, but:
I think the purpose of the laminar lip is to create "jet" of air that effectively extends the screen. That is why it doesn't have to be right at the tip.
With that in mind, it should be most effective if it is slightly angled from the screen so that the biggest gap is toward the front and the smallest at the back edge.
That gives the air on the screen the idea of being "laminar" ( layered parallel to the screen) and the squeeze gives it a kick up the arse to speed up and shoot out beyond the screen screen edge. The oncoming air then treats this a an extra bit of screen.
I often see people angle the lip so that it is angled the other way and trying to kick the air higher but I think that will be less effective - but I'm going on gut feeling and experience, I haven't fiddled with that particular doodab.
(Notice that on the Givi airflow screens the top panel angles away at its bottom/front edge, to isn't parallel or "spoiler" fashion)
In the old days we would tape bits of wool all over to see what was going on, so if you've got time on your hands.......
On the noise side, more noise doesn't always mean more turbulence. Smooth air hitting your helmet might cause more noise if it now being concentrated into striking a join, edge or tight radius.
