New Xmax 300
Normsthename
Re: New Xmax 300
Post by Normsthename »
Have any Xmax 300 owners fitted an Optimate lead?
If so where do you route the cable out?
1975 Honda GL1000 Goldwing
Ralph
Re: New Xmax 300
Post by Ralph »
Not done it but was thinking of running one into the right hand glove box by drilling a hole in the back.
Ralph
Nr Fleetwood
muddyfox
Re: New Xmax 300
Post by muddyfox »
Ralph wrote: Wed Oct 17, 2018 10:11 am Not done it but was thinking of running one into the right hand glove box by drilling a hole in the back.
Mine is fitted in the right hand glove box but I did not need to drill a hole. There was a rubber tapered bung with a flat head on it . At first I thought it was to adjust the headlight as there was also one in the left glove box. After a gentle twist and pull it came out reviling a hole.
Muddyfox (Nottingham)
Ride safe
Ralph
Re: New Xmax 300
Post by Ralph »
That makes it even better..
Ralph
Nr Fleetwood
Deleted User 7142
Re: New Xmax 300
Post by Deleted User 7142 »
Thats good news as i need to fit my optimate lead pretty soon.
(Muddyfox).Was it easy to do and how long did it take you?
muddyfox
Re: New Xmax 300
Post by muddyfox »
eame64 wrote: Thu Oct 18, 2018 12:06 pm Thats good news as i need to fit my optimate lead pretty soon.
Relatively easy. Battery above headlights and behind a bit of fairing on my 2014 X Max 250. Twenty minutes tops for the job.
Ride safe
Normsthename
Re: New Xmax 300
Errr... don't you just plug the supplied Optimate lead into the 12v socket in the left hand glovebox and charge/top up/maintain the battery that way
Not sure it’s possible because I don’t have my Xmax 300 yet..... :twisted:
Some 12v power outlets only work when the Ignition is turned on
Ralph
Re: New Xmax 300
Post by Ralph »
The plug in the left side is only live with ign or with the switch in the open position so don’t think it will work
Ralph
Nr Fleetwood
Re: New Xmax 300
Very few scoots have 12v power output sockets that are live without the ignition on.
Deleted User 7142
Re: New Xmax 300
Well i got round to fitting the optimate lead yesterday and as suggested i routed the cable from the battery into the right hand glove box.The glove box is only held in by three screws so i cut a small section out of the back and my lead was just long enough to fit through.As well as taking the front panel off i also removed the screen as it just gave more room to connect the leads to the battery.
Regarding the cutting of the glove box there is a small section that can be cut with a sharp stanley knife and theres is no need to drill.
