I'm lazy so would probably just make an offer on an ebay one, for example
https://www.ebay.co.uk/itm/205267590555 ... ondition=4
Or pick up a cheap new injector from aliexpress. Just pull the hose from the existing one and swap them.
honda fes 125 s-wing pantheon not starting help plz
- Argyll
- Current Ride: SH125 Mode
amebb
- Current Ride: honda fes 125 s-wing pantheon
Re: honda fes 125 s-wing pantheon not starting help plz
HiArgyll wrote: Mon Oct 13, 2025 8:18 am I'm lazy so would probably just make an offer on an ebay one, for example
I have removed the old injector and checked its resistance and that is all within parameters.
The injector was cleaned in an Ultra Sonice tank and then forward cleaned and reserve cleaned using Car Carb Cleaner spray. This cleaned the injector and I will reassemble it all and see what happens next
Andym
Don't forget the ECU can only raise fault codes based on electrical information, so either the injector solenoid or a sensor upstream of the injector.
You need to carry out physical tests not just believe the electrical data. With a injector, take it out of the engine, direct the flow into a container and fire it up, see if petrol actually moves.
amebb
Hi AndyAndym wrote: Thu Oct 16, 2025 10:16 am Don't forget the ECU can only raise fault codes based on electrical information, so either the injector solenoid or a sensor upstream of the injector.
Yes i have removed the injector and tried starting the bike to watch the fuel flow and also to watch the spray pattern too.
So, there is fuel there and a spark but no start.
Andym
Compression reading?
amebb
Hi Andy
I have not been able to complete a compression test using the compression testing tool that i have. The tool i use is for cars and i need an adaptor to fit my inpection tool into where the spark plug goes.
Having said that, i have placed my finger over the spark plug hole whilst we have tried starting the engine, and there is compression there.
The engine should still start or combust the fuel in the cyclinder as i turn it. But i get nothing at all.
- Argyll
Presumably your Haynes manual shows you how to check the timing. Have you done that yet?
amebb
That is the weekend job. To check timing and make sure that everything is as it should be.Argyll wrote: Thu Oct 16, 2025 9:18 pm Presumably your Haynes manual shows you how to check the timing. Have you done that yet?
Andym
Timing is about the only thing left if you have fuel, spark and compression.
amebb
Is the timing a common issue on moped etc?Andym wrote: Fri Oct 17, 2025 4:01 pm Timing is about the only thing left if you have fuel, spark and compression.
