Early Burgman 400 restarting issues before warm
- The Bern
Re: Early Burgman 400 restarting issues before warm
Check your inbox Carl, if any prob's shout me & I'll send you a different linking method
Have wheels, will travel
- primalcarl
- Current Ride: S-Wing
Cheers Bern, that's fantastic got your email
I charged the new Yuasa battery overnight using my optimate charger. It was reading 13.2v before I put it back on the bike this morning.
It started! I was able to ride it home. So I'm now thinking that there could still be resistance on the starter that the old battery couldn't overcome, a charging issue with the bike or a crap battery. I'll check it over before risking going anywhere else!
- The Bern
My pleasure Carl, glad it worked OK budprimalcarl wrote:Cheers Bern, that's fantastic got your email![]()
- Current Ride: nil
As Pikey says eliminate possible charging probs before going down the mechanical route. I did find on my 400y - if you use the steering lock 1 click to the left locks the steering - 2 clicks puts on the parking light front and rear - this flattened my battery in a few hours
Hope you sort yours soon.
- Current Ride: Burgman 400 2000
Interesting fact, I have a Burgman 400 from 2000 and always wonder why there was a cable link to a bolt and then nothing. It broke and I never thought of it much. Where should I connect the opposite part to the bolt?kayz1 wrote: Mon Jul 04, 2016 8:17 pm While you are in at the starter, fit another earth cable motor to frame. The early burgers ( 400 ) had a bad earth cable, just find a bolt on the frame ditto motor and fit another to help it along.
Thanks
