New Xmax 300
Scootypuff snr
Re: New Xmax 300
Post by Scootypuff snr »
charles1976 wrote:
Hence bought the 300 in blue pick up week on fri!
Thanks for the time to feedback.
Glad you've made a choice it sounds great and blue so not the dull colour option most seem to offer.
charles1976
Current Ride: shopping around
Re: New Xmax 300
Post by charles1976 »
Can anyone help with the running in period......
StephenC
Current Ride: Kymco DT X360
Re: New Xmax 300
Post by StephenC »
charles1976 wrote:Can anyone help with the running in period......
I stuck pretty closely to the book, so I think it was 45mph for the first period then 55mph for the second part. Couldn't tell you what happens if you don't do that
It was painful, but then it is with all bikes.
Can is not the same as Should
Ralph
Re: New Xmax 300
Post by Ralph »
4500 revs for 600 miles then a oil change and 400 mile at strangely 5400 rpm it does say this can be exceeded for short periods and you will find you do as it is eager to rev, speeds are as Stephen says,
the brakes will be weak till they have about 200 miles on them so watch it at first they are then very good.
Ralph
Nr Fleetwood
Scootypuff snr
Re: New Xmax 300
As per the owners manuel though I remember a suzuki (address 110 I think) saying quarter throttle first 600,then half throttle next 400 mile which was downright dangerous in our road conditions.
I don't think the odd extra revs hurt loading the engine.
charles1976
Re: New Xmax 300
Thanks chaps, appreciated. How hard is it to adjust the handlebars
Ralph
Re: New Xmax 300
Post by Ralph »
A bit fiddly but I think worth it, take off the silver cover in the center of the bars with allen key
you will see the bar clamps they have 4 allen bolts I maked the bars so I could put them back were
they were if needed, undo the bolts you then have to turn the claps round or swap them side to side
cant remember which as there is a peg that locait's in the bottom clamp and tighten it all back up,
the hole you are working through is a bit tight and so things are a bit fiddly but that's how I did it,
it is likely you are supposed to take the plastic covers off the bars but I didn't as they were a tight fit
and did not fancy braking anything.
Ralph
Nr Fleetwood
StephenC
Re: New Xmax 300
Post by StephenC »
charles1976 wrote:Thanks chaps, appreciated. How hard is it to adjust the handlebars
Haven't tried it. Moved the screen a few times but concluded that it is better at the low position.
Re: New Xmax 300
Normally up to 600 miles (1st service) then have a little restraint for a further 1000 miles approx. The book usually says something like sticking to 4000rpm which would be pretty useless as it would limit you to 40mph - don't worry about that, just be reasonably gentle with it, to begin with.
charles1976
Re: New Xmax 300
Sounds like A roads for the first 600 miles ish but no dramas, I'll see how we go. Don't way to spoil anything!
