no spark at plug
steve campbell
Current Ride: 2016 400 Burgman BMW 1200rt
Re: no spark at plug
Post by steve campbell »
roadster wrote: Sun Aug 04, 2024 9:47 am No one has directly mentioned the kill switch except by inference, so its definitely worth bypassing that before looking for the expensive stuff.
The kill switch is working in that it does not allow the starter to engage.
steve campbell
Dave Weller wrote: Sun Aug 04, 2024 10:00 am The micro switch on the left brake (Silverwing) is a double action switch which requires to work to complete the starter circult. I made up a wire connector to bypass it. Think its the same point of failure on the Burgmans.
b
hmm that is interesting, it was as I applied the brakes that the engine stopped..it might worth a look at the left brake switch?
steve campbell
just reconnected the switch and predicatably the starter doesn't spin when the start button is pressed
when I bridge the connecors the starter would spin on demand
OK coil off (at last) what a PITA
the primary winding reads 2.0 ohms Haynes says 3 to 5
The secondary winding read 21.2 k ohms haynes says 17 to 30 so it seem like the primary winding is at fault
do any gurus know us 2.0 ohms primary is low enough to cause this total lack of spark at the plug?
Thanks for all the help this far
steve campbell
coil is off (at last)
Haynes says primary 3 to 5 ohms, mine reads 2.0
Haynes says secondary 17 to 30 k ohms.minreads 21.2k
Would 2 on the primary be too little to provide any spark at the plug?
Andym
Post by Andym »
Any signs of heat?
2 Ohms is pretty low, not much inductance available in what's pretty much just a length of wire. If it's wrong it's shorted to itself. It's not an impossibly low number though, Haynes can only publish what they measured and none of us own a calibrated meter. A nice open or dead short is a much clearer answer.
This is where an old school dealer would make all the difference. Take the one they want to sell you off the shelf and measure it. 2 OHMs you don't buy it, 4 you do. Not typically a current option though. I wonder what the returns policy is at Wemoto etc?
Personally, given you agree with Haynes on half the numbers I'd order one.
steve campbell
Posted this earlier but ir didn't show...let's try again
steve campbell
Andym wrote: Sun Aug 04, 2024 2:29 pm Any signs of heat?
Agreed a dead short woul d have given me more confidence but I've ordered one now and fingers crossed that'll sort it out
You may have guessed I'm nuts, bolts and bearing guy and not an amps ohms an Ohmygoodness this is all greek to me type
Do they fit a centre stand switch on the 400 models these days. On the B650 the switch corrodes and the scoot will not run properly stays in first gear.
My K9 Burgman did not have this safety switch, but the health and safety rules may have made them fit it to later models to stop people riding off with the stand down.
Andym wrote: Sun Aug 04, 2024 2:29 pm 2 Ohms is pretty low, not much inductance available in what's pretty much just a length of wire. If it's wrong it's shorted to itself. It's not an impossibly low number though, Haynes can only publish what they measured and none of us own a calibrated meter. A nice open or dead short is a much clearer answer.
I do, an expensive one to buy, that gets calibrated every year to keep the conditions of my industry regulation as an electrician.
On cheap multimeters I'd consider 2 ohms to be in the same order of magnitude as 3-4 ohms.
steve campbell
capitano wrote: Mon Aug 05, 2024 7:34 am
Mine is a decent quality autosensing min/max multimeter but I am still concenred that even at 2 ohms it should trigger something
your thoughts are most welcome, electrics are not my strong suit
