Significantly cheaper than a Tmax!
SH350 ? Or 300.
Re: SH350 ? Or 300.
Re: SH350 ? Or 300.
Definitely the Forzas are expensive. But then, so are most Hondas. I was a Honda person through and through when I first started biking 51 years ago, and they were good alright. I had almost every bike they made under 350cc. Loved them. None of them ever let me down and I did BIG miles on them!
charles1976
Re: SH350 ? Or 300.
Changed my mind! Not sure about the feet position having sat on one yesterday much prefer feet forward on burgman
MATTTT
- Current Ride: Honda c90
Re: SH350 ? Or 300.
Well managed to find a 2016 keyless version with topbox guards and heated grips
Its been great ,narrow and nippy,good on fuel and not too bad over the numerous pot holes around here
Does anyone know the spare capacity of the charging system ? Im going to wire up a Keis heated jacket cant recall fhe exact current consuption without double checking,its probably 5 amps or so,(60 watts)
Managed to search out the output is 240watts ,although no mention of what years model this covers
Re: SH350 ? Or 300.
240w is not very much. My GTS (sorry to go on about it!) has a 450w alternator and that leaves me with about 7-8watts available for heated grips etc. I haven't any tech experience on the SH bikes but if you only have 240w alternator you won't likely be able to run very much. I'd check with your dealer on this.
MATTTT
Re: SH350 ? Or 300.
Found another posting someone said its actually 368w at 5000rpm,that was a 2011 model though ,so the one before mine
