Burgman 400 K9 for spares - value?
- capitano
Re: Burgman 400 K9 for spares - value?
Links work just fine.
Rust needs treating yes but looks worse than it is unless can poke holes in it .Even then could be welded .
- capitano
Don't rush to give an answer. At least talk to Jaz first.Walklikegump wrote: Tue May 19, 2020 10:47 pm
He is asking what I want to do with it so will need to decide tomorrow.
Feel a bit rushed and not happy with it tbh.
Can someone tell me if the links work ?
Stibbs
While you’ve got it stripped back I’d use a gentle wire brush on that rust to check it’s superficial. If that’s the case then liberal application of ACF50 is the answer. It’ll arrest the corrosion that’s there and prevent it getting worse. Looking at your scoot I’d guess it’s fine and nothing to worry about. You probably just need to replace a part to get it running. Sorry I can’t tell you which one. But yes, I agree with others, don’t rush into it. I’d say if you get running with a bit of TLC you could easily get a grand for it. Good luck.
I'd pay a grand running and full mot
Just brought a bike shelter got room outside for one now
Wife permitting
Why is he messing about with the coil when the fault code says fuel pump? PM sent...
Rocketman122
- Current Ride: eee
Curious what the outcome was?
200 is little. You can sell many parts for at least 1k
Did he show you no spark?
Could be coil. Could be crankshaft position sensor and also fuel pump. You can get a pump and replace yourself. 25k mipes is little. If it was always well maintained. oil on time and at proper level always
Rust is another flaw of thr b400. Nothing new. Also grounding battery wire issues corrode over time. A lot of fog/rain in uk
You are not doing your own maintenance so it may be much for you to deal with. It could also be your computer contacts are dirty.
The ecu sits in front of the large glove box but under the front cowl/face/fascia or whatever you call it. Mitch has videos how to remove. Not hard at all. Around 16 screws and some garbage (another desigb flaw) plastic push rivets that will break and need replacing over time.
The b400 has a lot of "known" flaws
If you part out the bike id buy some parts from you
