Scritching at rear of the Silverwing.
The Bern
Current Ride: Silverwing 600
Re: Scritching at rear of the Silverwing.
Post by The Bern »
Are you certain it's the clutch bud ?? Aside from the needle roller bearings in the middle of the hub that need greasing (as mentioned earlier) there is a 'sealed for life' bearing in the outer cover that supports the clutch drive shaft outer end, if that's come to the end of it's service life it will be running dry & liable to screech.
Have wheels, will travel :D
