Burgman 400 final drive bearing
Re: Burgman 400 final drive bearing
Keep an eye on the input shaft seal and the drive shaft seal if you reused them as they are easily damaged without you knowing when doing this sort of thing. But I guess you know that. Well done!
schwalbe
- Current Ride: Burgman 400 K9
I thought you meant the case seal. I replaced the shaft seals with standard seals
well done lad
schwalbe, did you notice how much gearbox output shaft (rw drive shaft) end float was present? It's usually quite a lot but I'd like to know if you took any notice of that as there doesn't seem to be any written down figures for this. Cheers!
