Bethie wrote:But if it needs it doing, why not just get it fixed properly? Rust spreads right and if it has corroded enough to make an inch sized hole then how long would a weld actually hold up for?
if you think you may only have the scoot for two years then you will be ok... or do you spend £250 on an aftermarket exhaust, as i cant seem to find a used one anywhere or £450 on the peugeot one... it all depends on what you going to do or keep the scoot.. all the other cash can be spent on your service items for three services ... just a thought, if the hole is on the outside skin then the central inside should be fine, as metal rust usually corodes in a place and works outwards, get a garage to weld a patch then grind/clean down the weld then get them to use high temp spray on the exhaust , will probably cost you £50 or cheaper if you know them.. it will look like new when the heat shield on...
