Help before i scream
Re: Help before i scream
also found these guys in uk http://www.patternparts.net/Products/Mo ... odelID=800" onclick="window.open(this.href);return false;
dont show the part but they may be able to get the patern part cheaper than suzi dealer
michaelphillips wrote:be carful when taking out the oxygen sensor .... they are very expensive if you need to replace that bit :D
Couldn't you just blank off the oxygen sensor if you damage it instead of bothering to replace the sensor? The bike should still run fine as the ECU will just run to a base map for fueling.
sorry dont know about this .. out of my depth never owned one :D
Well from what I understand (being on a number of bike forums and reading what others post) is that the ECU has a base map. The ECU monitors fueling via the oxygen sensor and adjusts fueling accordingly (mainly for emissions I believe). If you blank off the oxygen sensor port in the exhaust the ECU just runs to pre programmed base map. The bike should still run fine though, but will probably run a little richer and obviously use a tiny bit more fuel in the process.
However, I'm not an expert in these things and I'm sure others may come along and correct any points I may have got wrong.
You can buy a dummy O2 plug for most bikes on E-blag...they have a resister in them to fool the ECU into thinking it is still conected..if you need the O2 sensor pipe but can not get it, get the standard one and i will send you a Suzuki threaded sensor boss to weld into the pipe..
This is stub pipe £65 complete exhaust £580
http://www.suzukiscooterspares.co.uk/sp ... -000&uid=0" onclick="window.open(this.href);return false;
You could have saved a load of money last time with vibes but you wouldnt listen and sent it to Suzuki dealer
masterchop
Current Ride: Burgman K3 400
Post by masterchop »
Just quick update from work. got the part on order from Fowlers.
Single cylinder rumbler
masterchop
Took off the lower side panel yesterday preparing for the part to arrive. the pipe has literally snapped in two!
