forza v js300 v x10 v sym 400
- SkuTorr
- Current Ride: Tmax Mk3
Re: forza v js300 v x10 v sym 400
Don't forget the KYMCO Xciting 400i...will be coming to the UK and the US!
2009 Majesty 400 (sold)
Yes - definitely one to check out.SkuTorr wrote:Don't forget the KYMCO Xciting 400i...will be coming to the UK and the US!![]()
charles1976
Any idea on release date of kymco 400
- StephenC
- Current Ride: Kymco DT X360
And it'll have ABS
Can is not the same as Should
- irev
- Current Ride: AN400
The Kymco could be the find of the year if it genuinely weighs only 200 kilos and actually has 35 hp and ABS... at £4,999.
It will make it 22 kilos lighter than the Burger 4, with an extra couple of ponies.
Ponies are pointless, but the weight will benefit every single aspect of performance.
And the price point will kill the Burger at £6,399 for the ABS version.
As long as you like black...
charles1976
Very tempted!
- spaceprobe
Sadly it won't be as good as the Maxsym 400 ABS but then I would say that
- irev
At the money, I'd probably go for the 600 - it's still hundreds cheaper than a Burger 4.spaceprobe wrote:Sadly it won't be as good as the Maxsym 400 ABS but then I would say that
The Maxsym 400 is 229 kilos, pretty much same as the Burger, so at the same price £4,999 as the Kymco the Kymco should be cheaper on tyres, more efficient, and have some handling advantages.
It's really all down to dealers and support, accessories and running costs. I havent removed the Syms from my shortlist yet - but test rides will be a must.
- Globs
The Piaggio X10 350's dry weight is 200kg too.irev wrote:The Kymco could be the find of the year if it genuinely weighs only 200 kilos and actually has 35 hp and ABS... at £4,999.
If you are up north consider the SYM Joymax 300.
Compared to an RG1200 the X10 is small but compared to the Forze it's big - best to try sitting on them to see which one fits best before deciding too much....
charles1976
Had x10 and sym before...both rode totally different....had nc700 dct loved the power but not riding position....test rode bmw gtc650....awesome machine with a price to match.....grrrrr choices!!!
