MrGrumpy wrote:But I don't think they are that different. There have been some improvements, but the fundamentals haven't changed at all.
That's my thought too but after some research I did online I realised there is more than meets the eye
(Thanks to google for translating and you know who to blame if some sentences don't make sense)
Reduced friction inside CVT which improves fuel efficiency by 15%
New valve springs, better bearings, low-friction piston rim, better clutch material, etc. - better engine response and power delivery
New fuel injectors, new ECU maping and adjusted firing timing, plus low-ratio final drive for better mileage when cruising
Improved CVT module - less time for gear shifting and more responsive
New ABS control unit - smaller and 55% lighter; floating brake discs fitted
Improved suspension - firmer and better dampening
Other improvements include:
* reduced engine-braking (it was much stronger when compared with other maxi scoots)
* wheelbase is shortened by 1cm; not much on the book but claimed to make the bike more agile
* much more stable around corners
The keynotes are "borrowed" from a Taiwanese bike forum (Jorsindo.com). One of the forum admins is an owner of an old burgie with more than 27,000 km (17k miles) on the clock. He was disappointed by the "obvious" upgrades when the news about the new model hit the pubic but after been invited to JP for test ride, he said "I can't wait to upgrade to the new model".
