Bad day
Re: Bad day
ridinhigh wrote:oh im now wondering how hard it will be to get to p-lug on my X-EVO 400 CC
should be a doddle as you have an inspection hatch either side of were your feet rest, should be able to see it if you remove the panel on NON throttle side so you will have easy access :D
jamie
Re: Bad day
Post by jamie »
yep 2 minute job .. take screw out of the flap gently prise it up and pull it towards front of bike at same time ,,, plugs right behind it .... its a well thought out bike no panels have to come off at all for general servicing
StephenC
Current Ride: Kymco DT X360
Re: Bad day
Post by StephenC »
Last year I went to clean a washer jet on the Scenic. Couple of minutes, I thought. And then I dropped it down into the engine bay. Took me 2 hours to get the little bugger. Had to take a wheel off and all the underbody aerodynamic plastic cack they stick on cars nowadays. Only got a couple of cuts and scratches.
I should have just gone and bought another (£3?) but I was determined not to be beaten.
Can is not the same as Should
Re: Bad day
God - when I saw the title Bad Day, I thought this was going to be some accident or something! So having difficulty with a spark plug isn't THAT disastrous!
I remember reading that on some old Lagonda or Bugatti car, to change the spark plugs the first thing you had to do was to take the rear wheels off - so that you could dismantle the rear axle, to be able to remove the prop shaft and gearbox, so that you could then remove the engine.......
ridinhigh
Current Ride: GTS 300
Re: Bad day
Post by ridinhigh »
sorry to highjack thread but what spark plug, is a sport plug?
smeghead
Current Ride: GTS 300 Touring
Re: Bad day
Post by smeghead »
I looked in the book and it seems a simple job on the Majesty. I can't even contemplate how to replace a burnt out headlight bulb though, the manual says take it to a dealer. God almighty what were they thinking of at the design stage if you can't change a fucking bulb!
StephenC
Re: Bad day
Post by StephenC »
smeghead wrote:I looked in the book and it seems a simple job on the Majesty. I can't even contemplate how to replace a burnt out headlight bulb though, the manual says take it to a dealer. God almighty what were they thinking of at the design stage if you can't change a fucking bulb!
So they propose that you wait for roadside assistance if your bulb blows when you're out at night? And then wait again until the dealer opens the following morning? Oh, and then they probably won't have the specific bulb in stock (cos all they keep handy are bits for "real bikes"). Not very satisfactory. I thought only French carmakers were comedians like this.
smeghead
Re: Bad day
Post by smeghead »
Oddly enough I have a new car which needs the grille removing followed by the actual head light unit to change the bulb! Lots of cars need dismantling now to change headlight bulbs. I thought that it would be simple to design a unit where the bulbs slot in via the top of the unit rather than the back, seems simple to me!!
Re: Bad day
ridinhigh wrote:sorry to highjack thread but what spark plug, is a sport plug?
http://www.briskracing.com/brisk-racing-lgs-spark-plugs" onclick="window.open(this.href);return false;
THEY HAVE A SILVER ELECTRODE.. burns more efficiently over three grounding points from the electrode
you can email this seller and get the one for your scoot below :kiss:
http://www.ebay.co.uk/itm/360394108178? ... 1438.l2649" onclick="window.open(this.href);return false;
victor
Re: Bad day
Post by victor »
most things you can do will say take it to a dealer thats how they make money
