So this doesn't sound like an especially good ad for Puncture Seal! It didn't work as you had to resort to the plug! The temp plugs do work well, usually far better than their promised limitations imply.spaceprobe wrote:Car or bike, garages always come out with cant be repaired you need a new tyre. Now I know I am going to get jumped on but once again I am going to plug 'Puncture safe', 'Ultra Seal'. The night before my camping trip last month I noticed something in the rear tyre. The pressure was fine, but I decided to pull the thing out. It must have been in for a while because it turned out to be a large screw with the head missing. I had Puncture Safe in the tyre and it had made a tight seal around the screw. However with a screw PS recommend that you unscrew it rather than pull it out. This way Puncture Safe seals the hole on the way out, I did not do this so Puncture safe could not maintain a seal over 22 psi. So I also had to resort to one of those worm type plugs, that coupled with the PS seems to have made a good secure seal. Its been a month, I have been away loaded with camping gear, off road and sat between 70 and 80 mph on the motorway. No problems and no loss of pressure. My choice I know but I shall not be replacing my tyre until its worn out.
As I've said before the gunges have failed me before, and if they do fail, you are screwed utterly.
