Sat Nav idea's please
Re: Sat Nav idea's please
Post by Bluebottle »
That reminds me, I've got one of these you can have, or HG have just reduced them from £15 to 9.99
http://www.hein-gericke.co.uk/streetline-gps-tasche.html
Can get glare on the plastic window if its pointing skyward but ok otherwise
bornagainbiker
Current Ride: Honda Forza 300
Post by bornagainbiker »
I have a car TomTom Go750 Live and use this setup.
I started off with this handlebar mount for my Intruder M1500 http://www.ebay.co.uk/itm/GPS-SATNAV-CA ... 4cf67142bd" onclick="window.open(this.href);return false;
I now use one of these. http://www.ebay.co.uk/itm/330769229018? ... 1423.l2649" onclick="window.open(this.href);return false;
The waterproof case is generic with a rear mount mechanism for different clamps etc.
I bought the suction mount only to fit the case for just £11 plus p+p direct from Ridermount.
The suction cup has yet to become unstuck on both my B400 and B650 screens, but if your screen has too severe a curve then it might not work.
There are lots of 'Cheap' but effective widescreen sat nav units out there now and will fit this type of case.
I power directly using the supplied TomTom usb pc data cable via the 12v power socket and a 2000ma usb adapter, due to the power drain the standard 1000ma versions do not charge correctly and cut off, the price difference is minimal. I have to use the 90° cable due to the poor Burgman socket location.
Hope this helps.
NorfolkChris
Current Ride: Suzuki Burgman 400. 2000
Post by NorfolkChris »
alp231 wrote:How about a tunnel bag with a clear map pocket on the top pop your phone in there keep it dry etc?
Thanks but I have enough trouble getting on a normal bike as it is. I can get on the burgamn just nice a tunnel bag would be like a step back for me. lol
ridinhigh
Current Ride: GTS 300
Post by ridinhigh »
Im thinking of one of these,might do job for you
http://www.ebay.co.uk/itm/281007828674? ... 1438.l2648" onclick="window.open(this.href);return false;
NorfolkChris
Bluebottle wrote:That reminds me, I've got one of these you can have, or HG have just reduced them from £15 to 9.99
Thanks for the kind offer Bluebottle but a mate has a mount that may fit my phone and may suck onto my screen if it's flat enough
Bluebottle wrote:But if its any help, this way you can play scrabble at 70 mph:
I use this waterproof enclosure and mount and plug in my helmet speakers/mic or earbuds.
I'm using Garmin on an i-phone 4s but they do cases for all kinds of phones and sat navs as well as mounts for bars, mirror stems etc - same ball fitting as a RAM mount but a lot cheaper. They do waterproof, fused flying leads as kits so you can sort out your power if you don't want to get into soldering.
The case and mounts are from http://www.ultimate-mobiles.co.uk/
and I wrote about it here
Touch screens don't work with my motorcycle gloves so I picked up a cheap stylus or too to nick the ends off them.
Thank you Bluebottle for the info on that site. I've just ordered the perfect mount.... :D
NorfolkChris
Ok think I have it sussed now if I get this http://www.ebay.co.uk/itm/DC-12V-to-5V- ... 5d4245d1dd" onclick="window.open(this.href);return false; it will sit in the glove box beside the battery. A mate has a screen mount I can try to see if it is flat enough for a sucker mount. Hoping to try it tomorrow pm.
Big thanks for the replies it's good to get ideas and help
Liam
Post by Liam »
bornagainbiker wrote: I power directly using the supplied TomTom usb pc data cable via the 12v power socket and a 2000ma usb adapter, due to the power drain the standard 1000ma versions do not charge correctly and cut off, the price difference is minimal. I have to use the 90° cable due to the poor Burgman socket location.
Hope this helps.
Thanks.
This is probably why the garmin I just fitted, isn't charging. I checked mine and it's 1000ma.
I'll look on Ebay and upgrade!
spaceprobe
Current Ride: Maxsym 600i ABS
Post by spaceprobe »
I have had a Tom Tom Rider 2 for years and am very pleased with it. Ram Mounts do a very nice mount for it that goes on top of the brake fluid reservoir, works a treat.
Don't want to knock the RAM Mounts, they are definately good gear but Ultimate add-ons do the same resevoir mount cheaper. Both use the same ball size too so everything is interchangeable.
The materials may/may not be up to RAM quality, I don't know, but I haven't found any difference so far
